SiteSurfer
Yesterday - after a cracking (but a bit bouncy) sail into Portsmouth the engine (which had been working well for the 9 previous hours) died as we passed Gosport Marina. Having been discussing changing the boat out loud with my crew, I suspect that I deserved this bit of revenge by her.
I sailed onto a spare bouy and did all the normal stuff you would associate with what sounded like fuel starvation, on inspecting the paper pre-filter the bottom bowl was full of sludge, and no fuel was getting through to the engine. Working our way further up the supply chain I discovered that in a likelihood the pickup pipe is blocked with crud as I can neither suck nor blow down it.
What is irksome is that the tank is 3 years old (which I replaced after discovering the old steel one had corroded inside) and is one of these : http://tektankslimited.com/43-litre-fuel-tank-tt-5638-650-x-350-x-230-336-p.asp which doesn't have a bottom drain fitted. I thought I had been quite conscientious in adding diesel treatment every fill and being careful to try and keep a topped up tank. Clearly though I have had quite an awakening for even that complacency.
What I need to do now is to (I believe it's called) polish the fuel, have looked at some options and see that almost all require the bottom drain on the tank. As I can, albeit with a struggle, slide the fuel tank out to inspect it after disconnecting the deck filler - it should be possible to crack off the inspection hatch on the top and get all the gubbins out to clean it.
That aside - what to do with the approx 30 litres of fuel left? Should I bin it or attempt to clean it? I do have a filter like this : https://www.amazon.co.uk/s/?ie=UTF8...59&hvtargid=aud-443285814371:kwd-303817400809 which will start to help but I think I need to go further.
Has anyone a simple diagram for something that is made of parts that I could order online from Amazon/EBay which can filter from a fuel can to a fuel can and operates off 12V? I can mount it all on a chunk of ply etc, but just want a steer on the type of filter I should be ordering. Clearly - if the cost is hugely more than the price of the diesel it's not a totally realistic solution although it may be a useful tool to drain the tank yearly and do some ongoing preventative maintenance.
Finally, I'm intending to blow out the fuel line from the fuel tank all the way to the secondary filter, and then the return from the engine to the tank (they are all flexible pipes), ideally with some compressed air from a couple of PC blower cans - and then run some clean diesel through those (polishing it afterwards of course) before reconnecting the whole lot. I have heard that the cans of compressed air carry some moisture - anyone got any experience of this? Don't want to add to the problem. Alternative is to completely replace the fuel lines and CAV filter as they are at most 3 metres long.
Any ideas gratefully taken on board, thankfully it's not 100's of litres of fuel - but the breakdown of the engine whilst at sea is the same problem for everyone so if a solution to polish the contaminated fuel isnt financially viable I'll just bin it and start over.
