Maxi_10
We have bought a boat and plan to liveaboard from next April. European west coasts followed by Caribbean in about a years time.
I am just planning for winter re fit work on the boat, an Oyster 42.
If anyone has the time, experience and knowledge could they check over my power audit and power generation spreadsheet attached. Have I made an basic errors or wrong assumptions?
The first sheet Existing shows power use with the boat as it is both under sail and at anchor. The second estimates the power use after changing lights to LED's and adding a windvane self steering.
The power generation section on each sheet shows how many hours I would have to run the engine to replace the power used, how many hours I would have to run a generator to do the same. The the third option is to fit a wind generator and 140 w of solar panels, use these plus run the engine, if required, to make up the balance.
Does it make sense and does it add up? any thoughts welcome.
