Advantage
Active Member
Hey, have a quick question. For the facts, I have a 2007 Formula 400SS with VP 350's mated to DPH-A drives. I replaced the cone clutch and fork on the starboard drive last season.
I seem to be losing a little drive lube from my starboard drive the last couple of weeks. It wasn't obvious at first what fluid it was as I first thought I may have losing other fluids like trim, tab, or even steering. But, I believe I have traced it back to the drive.
Why the heck you can't check the fluid levels from inside the boat like with Mercruiser products is a poor design IMHO nor can you fill it up without pulling the boat out of the water.
Then, this weekend, there was a rather large pool of drive lube as I parked the boat in a slip at a restaurant. After about two hours and finishing lunch, we got back in the boat and she started to slip or slowly engage forward gear. Reverse not a problem. Symptoms felt very much the same as the cone clutch issue I had last year.
However, this time I believe the slipping is due to low drive fluid. Does anyone know if our EVC's monitor drive fluid levels? I assume they don't or I should have seen a low fluid warning. Also, I am having the boat pulled this week from the water to take a look at what's going on. Any advice or suggestions?
