NealB
Our old motor boat has sat ashore, shamefully ignored, for 4 years now (once upon a time, we used to use her mainly as a static houseboat).
5 years ago, both engines were fitted with lovely, shiney, new Bowman heat exchangers, just like the one in this little vid:
I now want to see if both engines will start with their customary ease and reliability, and have been checking things over and bleeding the fuel systems.
Both engines still look clean and neat, and they turn over easily (just for a few seconds).
So........... I'm trying to pluck up courage to see if they'll start.
However, the engines and gearboxes obviously have to slope down towards the stern to mate up with the prop shafts.
So it's quite understandable, even for one with such a simple mind as I, that the antifreeze mix will accumulate towards the rear of the heat exchangers.
In the starboard heat exchanger, the mix is still visible.
However, the port engine's mix has completely disappeared from view. A finger waggled around inside, comes out dry.
There's no obvious signs of any leakage, and I've tentatively tried adding just a little bit more mix, to top it up. I thought about a pint should bring it into view, so went for that.
Result: still no sign of the mix, so I then lost my nerve (sadly, I've never had any delusions of being a competent mechanic).
So .... please ...... what do the forum Gurus advise?
Should I be braver, and just continue adding more mix, till it shows?
Or could it be leaking to unmentionable, and possibly, serious places internally?
Thanks for any thoughts.
