Doc Holiday
I left my boat in the South of France at the end of July 2021 with both D3 22 engines running and starting very easily. They have both completed circa 180 hours of starting and running perfectly, but on returning to the marina in France at the start of October 2021, the port engine would crank but would not start. No fault codes were displayed and fuel flow could be monitored on the 2 1/2 Volvo penta instrument while cranking. Battery level does not seem to be the problem as it turned over very quickly and even with the emergency parallel battery mode engaged it would not start. The enginse have new air filters (the vanes of the turbo turn easily), the main fuel supply has new separate filters to both engines, and the engine fuel filter has no sign of water or contamination in it after draining the filter to examine the fuel. I made an arrangement for a local Volvo Penta dealer to visit at 08:00 on the Monday before I left. I turned up but the dealer declared at the last minute that he was too busy and could not test the engine with his Vodia laptop. I will not be back until January 2022 but would like any pointers at what I could look at and what could be wrong. I have swopped the main relays mounted on the engine with those of the starboard side and there was no change. The engine fuse was not blown and the circuit breaker was not activated. I could also press the fuel primer and hear the fuel pump feeding the engine filter. I hope it is something simple but I just don't know where to look anymore, any suggestions welcome.
