Marine Reflections
I’ve just ordered a silver line with a “cheap” optional 115mm pad which I thought might make it easier working in smaller areas. Is there a foam mop that’s ok but not quite as expensive as the 3m stuff or do I have to bite the bullet.
And where would I get one from?
____________________________________
Ebay would probably be the best place for choice, don't have to spend a fortune on foam pads. £2-3 each
Just make sure they will fit on your backing pad with a little to overlap, so if you have a 115mm backing pad, a 125mm pad will be ok.
You didn't say if you were compounding, polishing or fine polishing, but the pad choice is firmer for compounding to softer and softer the finer you go with the polish. And make sure you prime them first by spreading product into the foam.
Clean them often during working.
I only use foam pads for very, very fine polishing for many reasons, but hope that helps.
Tony
