scrambledegg
I'm undertaking the first service on my boat's diesel inboard engine. It's a Mitsubishi Sole Mini 33.
I want to change the water-separator filter and the fine filter and then bleed the air out of the system.
I've just completed an RYA one-day diesel engine course, so I thought I knew what I was doing. However, on close examination I've discovered that the engine doesn't have a mechanical lift pump with lever for manual priming, but instead has an electric lift pump.
This is what it looks like, the box-like object with the wire attached:
Does anyone know what the procedure would be for bleeding the system?
The engine manual is pretty terse on this point:
5.1.1 Bleeding air from the fuel supply system
(3) For engines equipped with electrical priming pump, operate the key to "ON" position. Do not run the starter motor for more than 20 seconds at a time.
The air bleeding from the injection pump and injectors pump is automatic
So i'm not clear if it will prime just by turning the key to "ON", or do I also have to run the starter motor?
Will the whole system self-bleed or will I have to open a bleed screw on the fine filter?
This is what the top of the fine filter looks like:
Any advice gratefully received!
Jeremy
Jeremy
