Norman_E
I have two of these compasses, both have air in them and need the oil replacing or topping up. The second photo shows the compass with the black plastic shroud removed. Is the part with two screws the plug covering the oil drain/filler? The compass appears to be strongly glued to a rubber gasket and will be very hard to remove. Should I try to remove it from its cylindrical base, or simply get underneath and remove the whole thing? I obviously need to get the filler hole to the top if I am to eliminate the bubble.
Finally is baby oil OK or is there something better?
