Strathglass
I was giong to tag this along with the posting on Harken / other furlers but decided not to introduce thread drift.
I fitted a Plastima 1012-T furling gear on Strathglass and it has worked well until now.
After four month's sailing the top swivel seized solid because of salt blocking the 'high tech'? bearings. I had followed their instructions to hose down the assembly with fresh water when laying up.
I had to end up first by unwinding the genoa fully at sea to untwist the hailyard wrap before I could drop the sail.
Fortunately there was no wind that night I stripped the assembly in Lossimouth marina to see if I could repair it.
As the bow of a moored boat is not as stable a platform as a workshop bench a high proportion of the balls ended up in the drink.
I did manage to do a temporary repair using the remaining balls and plastic spacers.
I now find that the only spare that Plastima list is a complete upper swivel and that the cost of bearings from other sources is prohibitive.
To replace the complete swivel would involve either stepping the keel stepped mast or disassembling the headsail foil as can be immagined
I am reluctant to do either of them.
I am quite confident that I can replace the missing balls in situ once the boat is out the water for the winter if I can source a set of balls.
I have not yet approached Plastima to see if they will supply them directly.
Has any formite a direct contact with Plastima such I can contact them directly and see if they can supply them? (probably in France)
Iain
Iain
