Is there a rule of thumb for power to weight ratio on a planning hull boat. Was speaking to someone today who said rule of thumb is 50hp to 1 tonne, anyone have any views/comments on this?
Hi Will With a single engine in a carrera I would think 165 hp minimum to plane lightly laden as you'll be about 2and a 1/2 ton. It might take a while to get up but will be economical for all your broads cruising and good for 24/25 knots and cruise at 20 knots
Proof of the pudding Early next season when my mate commisions his carrera with a new single kad 32 for £11000
cheers and good luck Joe /forums/images/graemlins/smile.gif
Will be different depending on whether you are talking diesel or petrol, the reason is the engine has to have enough mid-range torque to get the boat over its bow-wave and onto the plane, once there then Hp defines top speed, insufficient torque and she may not be able to plane at all without a seriously fine pitch prop.
I'd work around:
100Hp/ton if petrol (ie a 4.3 in a Carrera isn't big enough IMHO)
75Hp/ton if diesel
Top speed will be down on the diesel compared to the petrol (but maybe not by as much as the power difference implies), but they would give similar over-the-hump performance.
[/ QUOTE ] Right on
Also which planing hull? this can be anything from a "tea tray" to a full deep V with an acute deadrise all the way to the transom and any combination of the two, obviously power required will increase from that needed by the "tea tray" progressively towards the much larger requirement of the full blown deep V, and then there are cats, cathedrals dories etc. It does seem to me that the softer the ride you want the more power you need to achieve it.
David.
