PaulMcC
Hi All,
The plumbing on my boat is a mess. The toilet is on the port side with it's own seacock and works fine but I have a basin up forward and a galley sink by the companionway both on the starboard side. The drain from the basin runs under the saloon sofa, aft to below the galley sink where both flow into a shower sump type box with an orca bilge pump in it. This pumps out from the sump box, across the bilge to the port side, under the chart table, up the side of the hull to get round the battery box, in under the engine and then back to a through hull on the transom about 6 inches above the waterline.
The pump isn't automatic and also can't keep up if you empty the galley sink into the sump box, which of course isn't sealed and so leaks. Also when the box is empty and I turn the pump off, about 3 litres of water flow back through the long hose and this fills the box which leaks into the bilge.
Anyway I was wondering what the opinion on the forum was for the best new solution.
One option would be to install a seacock under the galley sink and connect both sink wastes to that.
Another would be to take the waste forward and tap it into the heads so it uses that seacock. (Not sure if that would solve the problem though as I'd have to decide which side of the heads raised loops to join it in.)
A third would be to keep using the through hull on the transom but to reroute the hose and install raised loops, non-return valves, replace the sump box with something waterproof. Etc, etc.
More modern charter boats I've been on tend to have extra seacocks for the sinks but I'd prefer not to cut extra holes in the boat so what set up other have.
PS - The boat is a UFO34 so has a very shallow bilge.
