owen-cox
Also just a point is that when an installation is new it does take a few hours to fully expel all the air from the system and then they output more heat. They do normally get to the point where its hard to hold your hand in front of it when its running after about 10 mins of running at full power though. Is the pump correctly angled up at the outlet and the pipe going up from pump to heater?The pump should run at 1.5Hz at full power about half the frequency of the chinese ones. Which controller do you have?
