zoidberg
I've installed an anti-siphon loop of heater hose between the heat exchanger and the steel exhaust elbow, which will carry exhaust water to be mixed with hot gas prior to entry to the Vetus plastic mixer bottle. As recommended, this loop comes up to the underside of the bridgedeck.
It is suggested that a Vetus siphon-break device be fitted at the top of this loop, which others suggest is an 'extra belt' to a belt-and-braces approach. Yet others suggest fitting a 'piddle tube' instead, which is a small bore tube inserted into the heater hose at the high point, and led out to a point above a cockpit drain, where the small-but-continuous dribble of water will be visible from the helm.
Should that stop while motoring, it would indicate a failure in the supply of cooling water perhaps just ahead of an engine overheat alarm.
I'm aware others have commented on this idea, but a Search fails to turn up much that's helpful. Would anyone with experience of this care to comment?
