Perkins intermittent starting problem
Tamar
9 Apr 2019
All over the shop
My Perkins perama sometimes struggles to start as if the batteries are flat, then it will start normally. I've checked the voltage and it's 12.8 on each battery. It happens when the engine is cold or hot. I've cleaned up all the connections and it's still the same. New starter motor perhaps. All advice appreciated.
Sounds like a bad connection somewhere. I had a similar problem on a club boat and had checked all the usual places such as battery terminals and connections and then took a jumper wire to the boat and clipped it from the alternator bracket to the battery negative. Engine started easily. The earth connection on the engine had appeared to be clean and corrosion free. However when it was dismantled it was apparent that a combination of aluminium,steel,copper and brass was not a good idea. Once cleaned up all was well.
Thanks, I'll give it a go later when the sun goes down a bit
Could be the starter solenoid fitted to the starter motor ( if that's the type you have.
The solenoid pulls a fork back that pre engages the bendix then makes the load across the contacts which then excites the starter motor.
If that is the type fitted.
Presumably the 12.8v you measured was with the battery at rest and ,measured across its terminals.
Can you check what the voltage reads while cranking (a) across the battery terminals and (b) across the starter motor terminals?
12.8 across the terminals the next day. Thanks for the reply
I took off every connection this morning, cleaned them up again until they shine, especially the earth when I noticed the earth cable from the battery once I pulled the rubber cover down was a bit loose in the crimped part, so I guess this is not helping. The engine started easily first thing, but then struggled next time, only just catching after turning over very slowly.
Today's job get a new earth cable.
What should a healthy voltage be when cranking?
I don't know, to be honest, but unless you have an amazing battery capacity I would expect the voltage to fall somewhat when you apply a big load like a starter to it. Unless the battery is significantly depleted the battery voltage will rise again to 12.8v or something near t that when the starter is turned off again.
The critical thing I suggest you look for is does the voltage while cranking fall further at the starter than at the battery? That would indicate that there is a significant resistance between the battery and the starter. (This would only be revealed when the cables and connections between the battery and the starter are carrying a heavy current, not when at rest.)
The curious thing about your case is the indication the problem is intermittent. If there is an intermittent resistance (e.g. damaged cable or joint that creates alternatively a resistance or not when moved) this will also affect the readings I suggested you take.
it certainly is baffling. I will try all you suggest later when it cools off a bit. I will change the earth cable first just in case. Thanks for the reply
Thanks, I'll give it a go when I get a day off.
You can easy remove the solenoid if you have access space without removing starter.
There is normally two screws and two soldered connectors to remove the cover.
Take careful notice and mark the position of the cover relative to the body as the solder terminals must be re connected in same position
