Perkins 6354HT injector pump advice
The Puzzled one
New Member
3 Apr 2012
West Country
I'm trying to sort out a small leak which appears to be coming from what looks like a second bleed screw on the underside of the injector pump next to the engine block. I can't get a spanner in here so wondered how easy it is to remove the injector pump to get a better look at the other side, then refit afterwards. Any advice would be appreciated thanks.
The pump is on a spline drive so take off all pipes and the 3 nuts holding it to the block ,there is a master spline so you can't get the timing wrong scribble a mark on the body and block before you lift it off,
Complicated process if you have to time it from scratch , won't go there,
Nice one Perkins paul
