Falcoron
As a newbie to boating I have an ocean 30 running a perkins 4.108
Couple of things I wanted to know,
1, if I have a single starter battery is this a 12v type? and what should the rating be on it ( no markings on this one and its not holding a charge so changing for a new one) What size should I get?
2, There is a steel header tank on the engine does this need to have water in all the time and what level do I fill it to? The cap for this is also loose, what type or temp rating do I get for this?
3, I take it this is cooled by the engine pumping water from the lake and out the exhaust, how much water should be pumping and how do you check if its working correctly?
I ran her for half an hour yesterday at tick over only and didn't see any water being pumped out the
exhaust. What and where do I check if all ok?
sorry is any of these are silly questions, but only easy when you know.
cheers
cheers
