Liz_I
Does anyone know how to test the heat exchanger for leaks. The calorifier was slowly losing fresh water and it seems that the heat exchanger is the most likely problem.
TIA.
TIA.
If the calorifier is losing water it is unlikely to be connected with the heat exchanger on the engine as the flow from the engine cooling system through the coil which is isolated from the boats water system.
