Peeing over the side
Urinating in public in marinas
Doing this in a marina or any public place is likely to end up with you getting locked up if somebody complains.
If females complain about it, you could very well end up on the sexual offenders register,not something that will do your career prospects much good.
Certainly in my experience sex offenders generally started out by flashing in public places.
At sea ,who cares.. only seamen...
Given that pee goes into the water anyway if you use the heads in the marina, the only objection to peeing over the side is seeing people in the act.
I do pee over the side if (ok, when) I need to get up in the night, but only do so in the wee (!) small hours when I can be sure there is nobody about.
Question from SWMBO; what happens with large ships, cruise liners and the like. Do they have an enormous holding tank, that is emptied when they get to sea, or does waste go straight out?
The water is treated, the solid waste extracted the water is reused for things like flushing the toilets. They compact and freeze the solid waste and then it is stored until they reach port where it is unloaded.
Neither - they have a treatment plant whose liquid output you can, in theory, drink.
Stavros has the same, although it's clunky and unreliable and seems to need constant attention from the assistant engineer (abbreviation to "ass engineer" perhaps not entirely coincidental :) ). On one trip I did, some plumbing problem down below meant they had to run the discharge up through a deck fitting and over the gunwale via a 3" hose - no volunteers to drink it, but certainly it didn't smell.
I presume there's some minimum size above which this kind of kit is mandatory.
scoop bailer is the best for under way opertions
I commend it to you
Dylan
I took your advice on this, can you please forward the name of your lawyer so I can seek compensation.
I had no difficulty inserting my dick and relieving myself. However, when I tried to withdraw I found myself trapped by a metal flap. The consequences, involving the RNLI, a locksmith and a plastic surgeon were distinctly embarrassing. SWMBO would like a word with you too.
In Norway 60% of the bodies found floating in the fjords during a season are over 50 years old, and 70% are found with their flies open - need i say more?:mad:
Seems like a good reason for encouraging the practice. Their contribution to the gene pool has probably already been made, they liberate housing, wealth and possessions for younger members of society, they do not require geriatric and social care. What's not to like?
And by the way, the latest research has shown that 83.6% of all statistics have been made up.
Right, that's Norway crossed off my list of cruising destinations, there's no way I'm sailing through Fiords full off dead men with their flies open :eek:
just a word of warning - if your mast is free standing it is much harder to pee over the side -
wouldnt recommend it as no shouds to brace against
Would you expect your next door neighbour at home to take a p**s in his garden in full view ??l No of course not ----------I think the same applies dunnit ??
