Refueler
The orientation of a metal mast has to be at 90 deg to the incoming signal in order to return it adequately. The mast is after all a smooth flat surface relative to the wavelength (usually X or S band) of marine radar. If the boat is heeling, and pitching, the return is severely attenuated as the return will head up towards the sky. I have yet to come across a mast that stays in perfect straight alignment while sailing. It is entirely possible that junctions of e.g. spreaders or the boom might fortuitously make a decent return, but such junctions do not have the engineered "perfect" right angles necessary to bounce the signal back strongly. It's not only a 90deg corner that is needed but panels big enough to send a beefy and worthwhile signal back to the transmitter's vessel.
This is why the tube reflectors are such useless items; they cannot present a big enough reflecting surface especially when tilted. A Qinetiq notes, the returns are very poor.
I agree with most of that ... but a mast is not a flat or true square on most boats ... most are an oval shape that gives any orientation of the mast a small amount of it reflecting back to the radar set.
Second if your sails are salty .. damp or wet - they can add to the RCS. Not a lot but every little bit helps.
Yes pitching rolling and movement alters the orientation of the mast and sails ... but that also can aid the situation ...
How did a 10,000 GRT container ship plot my 25ft boat from over 10nm on his ACAS when I had no reflector hoisted ... ??
