Parts to change from calor gas to french set up
pcatterall
2 Aug 2004
We have kept using our UK set up for the gas on Coral Wind but now we are med based we will have to consider a change over.
Can I buy the required part(s) here and take them with me when we travel out in spring and then buy the cylinders out there.
I guess that the basic part will be the regulator and then the pipe fittings may need changing?
can some kind person advise as to what I should take and advise about fitting.
many thanks
many thanks
Get a GABBOAT kit form www.whayward.com/ resold by SOCAL in Southhampton as well. everything you need for most systems.
Are you talking about converting to Camping Gaz? I fso you will need standard CG regularor which has a hose tail, so new hose + clip to cannect to your isolator valve/bubble tester. Pipe having what ever end fitting needed.
http://www.gooutdoors.co.uk/camping/cooking/regulators-and-hoses
Or an inexpensive adapter valve to fit the Camping gaz bottle on to which a hose with the standard calor butane nut, or even a butane/dual fuel regulator, can be screwed.
