BabaYaga
Hi,
I would appreciate your thoughts on the best way to wire in a paralleling switch in a system where both the starter battery and the domestic battery bank are fused.
In my boat the alternator output is wired to the domestic battery bank, via the positive busbar, a shunt (for the V and A-meters) and a 80 A fuse , close to the battery. There is no switch in this charging circuit.
The starter battery has a 250 A fuse close to the positive post. There is also a switch in the wire leading to the starter motor. In order to charge the starter battery, a 70 A relay connects the positive busbar to the load side of the switch in the starter motor circuit as soon as the alternator starts to put out.
Last year I decided to wire in a paralleling emergency switch, so that I could use the domestic battery bank to start the engine, in case my (rather small) starter battery became depleated.
I connected this switch to the battery side of the two fuse holders, so that I would still have the 250 A fuse in the circuit, even if I were to use the domestic batteries for starting.
However, I have started to wonder if this is the best approach. I have seen suggestions in this forum that it is better to wire the emergency switch directly between the domestic bank and the starter motor, bypassing the starter battery. I suppose the reason is to avoid the domestic bank draining into the empty starter battery before the engine is started.
What do you think is the best way? And how do switches with incorporated paralleling, like this:
http://bluesea.com/category/1/products/6011
deal with fusing of different amperage in starter and domestic circuits?
