dgadee
Having to buy two new house batteries, I fear. A friend says he never connects his together as when one starts to go it destroys the other and you need to buy two rather than one.
Is he correct?
Is he correct?
How does he use them then?
How does he use them?
My two 2 X 180Ah are still getting by reasonably well at 9 years old.
He says: "I use them individually, occasionally connect all when solar is producing excess."
When doing harbour movements on cathedral engines with air start the air receivers are always divided for the reason of having a full capacity in reserve. I always treat batts with the same procedeure.
As we are not using our house batteries to start our engines, it's perfectly normal to run the batteries as a single bank, in parallel.
Indeed, they are the full capacity in reserve. Mine are >6 X the starter battery capacity.
Maybe i could invent a 1-2-3-4-5-6-7-8-All switch![]()
