Paraffin as a cooking fuel
sideshowbob
28 Feb 2013
What is the consensus on global availability of Paraffin?
Does it have any advantages over diesel, again to cook with?
TIA
Interchangeable with heating oil and jet fuel.
Main advantages over diesel is that diesel fired cookers are quite rare and, as I understand it, like to be left on continuously- like a seagoing Aga.
I use odourless Paraffin in my Taylors.
I've got a Taylors. No problems with starting it up but not really as controllable as gas, although most of the time that doesn't bother me. Best to do a bit of pre-planning to avoid having to turn burner off between dishes/courses. For short blasts and kettle etc I put one of them portable gas cartridge stoves on the gimbals.
Our first boat had a 2 ring primus, it worked really well.
You do need to get meths to warm it up as well as paraffin to run it on.
I imagine it'll be easier to get paraffin in out of the way places. Folk don't like it here because gas/lekky is cheap and accessible.
Global, paraffin is the way to go. Cheap to run, plus easy and safe to stow anywhere. What's a "gas locker" ? Sounds like a massive PITA.
You cant use diesel in a paraffin cooker. You can use plane fuel though they love it... JetA1, Avturb, is 'global'..google how much slEasyJet etc pay for a litre..
Paraffin in the UK can be sent very cheaply in big drums to your boat from ebay suppliers eg Rye Fuels.
GLOBAL like the sound of that, what boat you got and what are your plans? regards Paddy The HOPEFUL GLOBAL
OK thanks for the answers.
As one poster put it Gas is a PITA for all those very good reasons.
Paraffin have never had a problem with using it or maintaining.
Diesel again as a poster says like a range so not so good in warmer areas.
Looks like the ideal would be a combination of either paraffin/induction or diesel/induction
Fuel of choice in India until the last five years or so. Still widely available though.
IMHO it smells better when burning; reminiscent of childhood.
Filthy stuff! What's wrong with gas, which is available in most of the world?
Also in Antarctica! Gas won't work in Antarctic temperatures; paraffin works fine. Also gas has the above mentioned drawbacks of weight etc.
Whenever 'paraffin vs gas' comes up, it tends to go the way of an anchor thread.
The danger is that people assume that their priorities are the same as everyone else's.
