Pantograph Wiper Replacement
[165042]
25 Nov 2016
I have a set of Doga pantograph wipers that are falling apart. Doga don't make them any more but have an alternative for close to £170 each :disgust:. I'm assuming I can't pop to Halfords for some but does anyoone know of a good make that aren't a silly price?
Been there...
I'm converting to pantograph and searched thoroughly before ordering.
Ended up with Roca W12 arms, coincidally cheapest from Watski at £48
Convincing quality when you hold it and take a closer look
I installed two pantograph Vetus units, even stainless versions are good value. The on-line catalogue has a sizing guide.
I do like the stainless ones but in my size they're over £100 each. I'll take a look at Roca as I've had them before, thanks!
You'll notice differencies in design. Some has the blade fitted to the primary arm, some to the secondary and some to bridging bracket - on the in- or outside. This decides if the blade runs centrally or to one of the sides of the motor fitting point
Take a look at the parts and pivot pins - they need to be capable of the load.
