tobble
I've tried searching for answers to the below but to no avail, so here goes...
Scenario: My Sabre 27 has 'crazing' all over the deck - small cracks likely caused by 35+years of UV on a gelcoat that was perhaps a little thin on layup. I'm now ready to sort this problem out, and want something that won't need doing again too soon. there's no paint on the deck at all at the mo. the majority of the horizontal surfaces have a diamond tread pattern like many boats.
1) What is the best stuff to use for
a. the non grippy bits - I like the idea of 2-pack polyurethane, and the premium over single pack seems worthwhile on the face of it in terms of longevity and durability - any comments?
b. the grippy bits - previous posts seem to conclude that sandtex is a cheap and robust solution.
2) depending on recommendations for part 1) - how best to apply? I have a spray gun and the yard have a tent, is it worth hiring/begging/borrowing/stealing a compressor? I guess time wise there isn't much in it if you consider spraying requires a bit more prep, but will the finish be better enough to make it worth while? I've done a little bit of spraying but am by no means an expert, although always keen to develop a new skill.
3) Where to put which paint - I mean, should I put the non-grippy paint on the whole deck first, and then put grippy paint on the grippy areas, or just put non-grip on the non-grip areas and grip on the grip areas... if that makes sense... I suppose this depends on the quality of the non-grippy paint.
4) In a similar vein, should I paint under all the deck fittings? I 've mentally allowed for removing all the cleats, winches, stanchions etc. also the mast is coming down (for a re-wire and to fit in the tent) - should I paint under the chain plates and the tabernacle or avoid disturbing these? one of the things I'm worried about is the deck-paint join under cleats etc giving up under stress and causing orrible looking bits or even leaks.
anything else I need to think about? Or am I making a mountain out of a mole hill and ought I to just slap on a few coats of Dulux?
thanks in advance for your thoughts.
