when ever i used to rebuild an engine i used to respray it all with international enamel that was used by our supply boats to paint their top sides. since retiring and not haveing a supply of free international i have used halfords spray cans that they sell for touching up cars. it works fine, the heat is not a problem. just be a bit careful near the alternator so that the spray drift doesnt get on the slip rings.
stu
If the engine has been in bits, no point doing it until you have done a few hours and had the rocker cover off to re-check the valve clearences and re-torque the head bolts.
Then, degrease, derust as best you can (I use acid), and I would suggest using something like Hammerite smooth which is self priming, has some resistance to coming off if painted over rust, and temperature resistant.
It comes in spray cans, about £7.50 from Halfords.
Paint everything except the alternator, drive belt, and little bras cover on water pump (if you have one). Good idea to then put a blob of red on all bleed screws.
(1) degrease with "Gunk" and wash off with fresh water. (2) abrade with wire brush in battery-drill or by any other means (3) clean dust off (4) if there is surface rust paint with Hammerite No.1 Rust killer or apply Hammerite "special metal primer" on non-ferrous parts (5) paint with hammerite smooth applying two coats in succession as advised on the tin.
The above has worked for me and still looks good after 5 years
Smoothrite works very well. I am almost certain that Bukh red engine paint is identical to this product, at considerable mark-up, of course. They make it in a variety of colours, including white. Available in most hardware shops, the smooth version of Hammerite.
I normally paint what was painted, as a general rule. Other than electrical connectors nothing will suffer any significant damage by being painted. Smoothrite dries so quickly that no damage to plastics and rubber will take place.
In my younger days when car engines were clapped out at a comparative short mileage compared to what we have now, I used to recondition my own engines. I used to repaint them after thorough degreasing with Woolworths paint! Afterall, the block will never reach much higher than 100 degrees centigrade and this worked quite admirably.
