pulsar
Hi guys, has anyone out there ever seen or heard of this problem with the subject genset before?
Late last summer our Paguro failed to output any AC voltage. The engine started fine and ran as normal, but no AC.
As it was end of season I left it for the spring job list!!!
Well, after 2 weeks of problem determination, tele phone calls and a visit by a marine electrician etc, the problem was discovered.
The rotor was not turning when the engine was running. Bizarre.
With some help I lifted the genset and removed the generator from the engine. (the genset is buried deep in the bowels of an old S&S Swan!!!)
What I saw was truly bizarre. The shaft of the rotor, 30mm steel had completely sheared where it goes into the coupler on the back of the flywheel.
No damage anywhere else. End bearing running free and no sign of damage. The rotor had not even touched the inside of the stator.
Now the genset was installed new in 2007.
I live in Malta and every summer we take the boat to Greece for 5 months cruising. So in that time we have used the genset regularly. To date I have 2700 hrs on the clock.
The genset has not been very reliable since the first season. To date 14 different problems have actually stopped the engine. Fortunately like most cruisers, I am electrically and mechanically minded so am able to fix most problems.
Now we come down to crux of the matter.
The genset was supplied from a dealer in the UK. I contacted them with a view of getting a new rotor.
Parts catalog showed a complete assembly was available, bearing, rotor and coupler. £500 ish shipped to Malta.
That seemed expensive but at least I could get the genset going again.
Then the bad news arrived by email the next day. The manuf had changed the generator and the only rotor they now supplied was for the new generator which was not compatible with my 'old' machine.( 'old ' machine, purchased new and installed in 2007!!!!.) Now the only parts I can get is a complete generator, shipped to Malta direct from Italy for £1800.
So if anybody has come across this problem let me know.
And any Paguro 3000/4000 users....beware of the change in generator.
Pulsar.....
Pulsar.....
