tt65
Has anyone ever been into Pagham? If so, can you give info on access, holding, rules and regs.
I was going to refer you to some info on the Pagham Yacht Club website, but it's gone. Big RSPB Brother?
Follow the shingle bank round on your port side to the bottom of Mill Channel. Good luck! The following may help:-
Bing Maps has an excellent aerial view of the harbour photographed at low tide and therefore clearly showing the channels. Go to:- http://www.bing.com/maps/#JndoZXJlMT1wbzIxKzR0YiZiYj01NC4yOTQxNDQ5NjE2ODY1JTdlNi4wNDI0ODA0Njg3NSU3ZTQ4LjU0OTQwNjg4NTgwNDMlN2UtNi4wNDI0ODA0Njg3NQ==
The nearest postcode to the Harbour entrance is PO21 4TB - enter this postcode, adjust scale and change to Aerial photo and drag.
The 1:25000 Ordinance Survey map (Explorer 121 sheet shows the approximate location of the channels). Or go to
http://getamap.ordnancesurvey.co.uk/getamap/frames.htm Enter the above postcode, adjust to scale 1:25000 and re-centre to SZ 877 961.
There's a quay there so there must have been enough water to get inside at some point.
You could not tie up there today as there are no bollards or rings that I can see.
Well I don't see how any boat could tie up there. It look as though there is only about another 18" to the top of the Quay so it would need some serious dredging before any yacht could get to Sidlesham.
It is a shame, the old adage use it or loose it seems top sum it up. Now it is really lost.
Half way between Barn Rocks and the Mulberry, 3/4 mile off the beach is a scour hole (see chart). Local work boats up to 40 feet have anchored here, but it moves so check it out with your sounder. (pot lines 200 yards East near rocks.)
