Paddle board mount
ashtead
17 Jun 2008
Surrey and Gosport UK
There are special u shaped brackets for the upmarket paddle boards -simpler to keep deflated in lockers though unless crusing I guess as doesn’t take that long to inflate with electrical pump surely
ylop
10 Oct 2016
If you use it at every anchorage would be a pita to do even do one board, and noisy in the tranquility… if you had two boards it would be more compelling. They don’t pack that small so again a couple of boards would be a lot of space inside a boat.
ashtead
17 Jun 2008
I guess it depends on space - we only keep below deflated until arriving at suitable location but the battery ryobi inflator makes short work of job on arrival and of deflating at end of trip. I guess if crusing for months might be tempted to keep on those pricey force 4 brackets .
markc
Bucks & St Raphael SoF
When you don’t own a vessel as impressive as this...the U shaped cradle mounts are essential...because you can mount them on the outside of the rails...and not take up any precious space on deck
The hook things look great, albeit a bit expensive, BUT a PITA to manage if moored close to the neighbouring boat. No problem in UK style moorings though.
Portofino
10 Apr 2011
Boat- Western Med
Found this the best way .
Doesn’t restrict vis , or interfere with tight Med stern too .
When anchored its chucked in anyhow to free up the ladder anyhow .
Doesn’t spoil the lines either FWIW ?
jcwads
20 Jun 2016
Antibes
i bought the Jobe rack a few weeks ago. It’s waiting for me at the marina to pick up. Am out tomorrow so will install and take a pic. They look slick from seeing another boat with one and out the way.
