lumphammer
I have two issues repacking my sterngland. The first is I am following the method of wrapping the packing tightly round the prop shaft and cutting at an an angle of 45 deg. Perhaps I don't have it tight enough but because of the spiral none of the pieces fit tightly round the shaft when brought together, so I end up trimming off some extra to give a good fit.
Is that normal?
The second more important problem is that I'm having real difficulty in getting the packing into the housing. I have measured the inside dimension of the housing at 2in and the propshaft at 1 1/4 so I've got 3/8 packing.
(Because of the location of the sterngland the inside dimension is my best measurement. I can't get the calipers in to do it accurately)
I've only managed to get one piece in so far by flattening it out with a roller and using the collar to push it in.
Should they be that hard to insert? If I go to 5/16 will that expand outwards to take up the space as I tighten up the collar?
Any thoughts would be gratefully received.
PS. My sterngland has a collar that slides onto two studs and is tightened down by a couple of nuts
PPS No - I can't fit a Volvo gland. The sterntube is too big
Is that normal?
