Dazzajohm
N/A
P385 soon to be available if you have an extra 8/9ft of mooring space, haha.
I’m always open to suggestions ?
The only fault that can be checked is the gear engages correct, a cone is £685 no gears are available. Best swap is either a PRM of ZF gearbox £5kI’ve been doing some more research online and apparently these TAMD 41’s are prone to gearbox problems.
Does anyone know if an issue with a gearbox is likely to get picked up on a survey (unless of course it’s obvious) and if at some point one needs replacing how much can I expect this to cost?
The issues are the ones I’ve saud . I’ve had 2 cornices and had to put tanks in one . For some reason it’s mostly the starboard that rots sway . Great value money boats , imagine what one would cost new today , I’d say 200k easily .
A nice clonk when engaging forward or astern is supposed to be good sign and a simple check is to remove dipstick and hope to observe clear fluid up to correct level, if nothing else it suggests that owner is aware of the importance of regular oil changes.
There is in base of gearbox little magnet, unfortunately it is hidden away in bottom bearing casting and not easy to get at and inspect.
Chum fitted a pair of ZF 45 A ?? to his Princess 33 fly when one of his MS4B failed recently.
Lancing Marine normally charge about £2.5K per unit but they do have one unit on special at £1.5K.
The real grief is time effort getting the whole she-bang to line up, the engine mounts need shimming and hopefully the shaft will pull back a bit before props bash the "A" brackets and faffying with oil cooling connectings.
Having said that somebody else had the box on his Princess 41 go last month and a few months earlier another member blew up a much fabled Velvet Drive 72 just the luck of the draw .
I have had my cornich for about 4years now, had all the holes you mentioned and repaired at low cost, just a bit of time and it will be as you want it.
It has 2 no tamd 41b on shafts and drives well, had a bit of work on the exhaust pipes, impellars , oil change on both engines and changed the bilge pumps .
A fine boat to travel in and very comfortable to stay on.
