dankilb
In the UK, the cost of G10 sufficient to cover all high load fittings would be prohibitive. Even making your own, the materials would add up. That’s why ply remains the prevailing solution for high stress areas. Marine ply plus drill-fill-drill should make it pretty fail safe.Thanks once again for your input gents.
The genoa car track is, I think, mounted on an area with a plywood core, which is for sure rotten (I‘ll see exactly when I open that area up, at the moment trying to deal with one area at a time).
The area of the inner forestay is clearly delaminated and has been well compressed with a pretty big deflection in the top skin of glass. I’m going to be using closed cell foam for all no stress areas, was thinking of G10 or similar only in high stress areas like under the davits for example.
