Oxalic Acid!
ianwright
Home: Peterborough, Mooring, Heybridge Basin
I last bought 20lbs oxalic acid at £1 per lb fifteen years ago and was running a litle low so I was pleased to find it a a sensable price again from
http://www.rydenor.co.uk
5 kg for under a tenner delivered, and it got to me in less than a week, not bad eh?
Normal disclamer, I'm just a yotti who would rather mix his own...
IanW
<hr width=100% size=1>Vertue 203, Patience
Mirelle
N/A
30 Nov 2002
Thanks. I feared, from the title, that you had discovered that it was no longer get-able due to some EU-type regulation. Happily not!
Neraida
1 Jun 2003
www.neraida.org.uk
Which way round is it again???
Water to acid or acid to water???
Think its the last one... Dr Barnes would probably lob his board rubber at me for asking that question...
<hr width=100% size=1><A target="_blank" HREF=http://www.ybw.com/cgi-bin/forums/postlist.pl?Cat=&Board=forsale>Bargain Laptop for sale </A>
VicS
13 Jul 2002
Acid to water applies to diluting sulphuric acid, in which case it is very important, but not any other that I've come across. Oxalic acid is what is called a weak acid and is not what I would regard as particularly hazardous to handle. Use of hot water to dissolve as suggested elsewhere is a good idea as it takes a while in cold water. Use non metallic containers.
Remember that it is quite toxic, so avoid ingesting, keep safely out of childrens reach and dispose of waste and residues carefully.
<hr width=100% size=1><font color=purple>Ne te confundant illegitimi.</font color=purple>
iangrant
By the Sea
Re: Why?
and does a fine job removing fibre glass yellowing above the water line and removing rust streaks and residual rust from stainless fittings..
Ian
VicS
13 Jul 2002
Re: Rhubarb
Yes that's right especially the leaves!
Perhaps you could grow masses of the stuff, extract the oxalic acid and make your fortune selling it to yachtsmen for cleaning off rust stains and renovating their teak bits.
VicS
13 Jul 2002
Re: Rhubarbinfo.com
"There just had to be a website.........."
and there just had to be someone who would find it!!!!!!
pheran
23 Sep 2002
The glorious South
So, having got your Oxalic Acid solution, how do you apply it to (say) teak decking? With a cloth/sponge/hard brush? How long do you leave it before washing off?
<hr width=100% size=1><font color=blue>A hangover is just the Wrath of Grapes</font color=blue>
ianwright
Just paint it on with a soft paint brush, enough to wet the teak well. You will see the bleaching effect within moments but leave it on for 20 mins then hose it off, and make sure not to leave any on painted topsides or varnish. Left too long on paint it will reduce the gloss,,,,,,,,,, but there is no point in leaving it on that long.
IanW
Joe_Cole
14 Feb 2002
If you are using it on the hull, or on any other vertical surface then the old trick is to mix it with wall paper paste to give it some "body". You need a very thick mix because, when you add the acid it thins it down a lot. As someone else has said, it works very well on yellowed waterlines.
Joe
