Angele
So what you're claiming is that builders are wasting their time mouldling 20mm?
But what about a sand bank, mud or some other surface that might 'give'. This is just as likely, or indeed a more likely a scenario, than hitting rocks. It's these cases that I would think that the additional thickness may be beneficial. Don't you agree?
I think it is more about the area over which the force is spread that will determine whether 20 mm is sufficient. I'd liken this to a horizontal sheet of GRP against which you (1) drop a (2.5kg) brick from a height of 10m, or (2) fire a (20 gramme) bullet. The brick will have more momentum (but less energy) than the bullet. I reckon there is a fighting chance of the GRP sheet surviving the brick, but not a chance with the bullet, because the entire energy of the bullet is focussed at a tiny point whereas the brick's energy is absorbed over a wider area.
So, by all means build GRP to a thickness of 20mm if it might receive a whack from a heavy object over a large area, but think of a different material (steel?) if it might experience a large force focussed on a single point.
