Nick_H
So having got rid of the Jet RIb (and good riddance), I've now got an Avon 3.1 m RIB, which states a max HP of 15 regardless of whether you use a tiller or have a centre console, which will not be enough to pull a skier, or probably even a ringo.
However the Avon 3.4 m is virtually the same, just 12 kg heavier and the length of a ruler longer, yet that will take a 25 HP with a console, which would be just enough, although still only 15 hp with a tiller.
Now the only things I can think of which dictate max engine size are engine weight, boat weight distribution, and transom strength. So, if I reinforce the transom of the 3.1 which is easily done, stick a 25 kilo bag of ballast in the bow locker, and buy a lightweight 25 hp 2 stroke (which weighs the same as a 15 hp 4 stroke), is that a reckless thing to do?
The RIB was bought used so is out of warranty anyway, and only I would drive it so I'm not too concerned about potential liability issues, so long as I believe the RIB is safe.
What does the panel think?
