jfm
Agree much of that Deleted User. All a bit imho but I too am pretty sure that virtually none of a mobo's shearing around its anchor actually gets seen as a chain angle change at the anchor. Different for sailboats though. While I would beg to differ with GSkip's claim that Bernoulli makes aeroplanes fly and shower curtians blow in (let's not go there, too much thread drift!) I agree with some of his Bernoulli on boats shearing at anchor
I suggest boats shear around the anchor because
(a) sometimes flapping with windshift (which any dinghy racer will tell you happens a lot, +/-5 degrees).
(b) becuase of gusting. In between gusts the boat moves forward under weight of chain. In gusts it blows back but as it does so it naturally starts to turn broadside to wind, as it drifts downwind. It gets partway then the anchor chain pulls the bow round, and it overshoots, so see-sawing.
(c)Finally, and this is where Bernoulli applies, a sailboat that is at an angle to the wind can literally sail with its hull as the aerofoil and the keel as the keel. Some tension in the chain keeps it nicely 45 deg (say) to the wind, so as to trim the rig. It will then sail forwards towards a point at the side of its anchor, till it sort of tacks and repeats the performance, hence see-saw sailing around the anchor. This happens a bit on mobos, but is more of a sailboat thing becuase mobos have lousy keels. When this happens it can break the anchor out. Indeed, this was the accident investigator's conclusion on Mirabella V's grounding in 2004.
