Tammany
Having overheat problems with my 1GM10.
Start engine from cold, water flow seems good and being ejected from the exhaust. After 5-10mins or so starts beeping with overheat alarm but at the same time their seems to be very little water coming out the back, certainly a lot less than from cold.
Attaching hose to water pump exit and water flow seems good, whatever is going on it happens as it gets hot so I assuming when the thermostat changes position.
Is this indicating a faulty thermostat or calcified/blocked cylinder head?
