Arctic Fox
Hi,
I am looking for some advice and guidance around the age old 'hot stuffing box issue. I think I know the reason but the more input the better, I think!
The problem is......I have recently re engined with a small Diesel. The engine was installed and lined up by a qualified engineer. I however, packed the stuffing box and tightened the packing nut etc. I did this as per the accepted methodology. I ran trials on Saturday but ended up with the 'Hot box'. By hot I mean I can hold it more or less indefinately but it wouldn't take that much to make it uncomfortable to hold. A summary of the pertinent facts are...
The shaft turns freely and windmills when knocked out of gear
There appears to be no excess vibration
The stainless shaft does not feel hot where it exits the tube
I get no water drips - even when the packing nut is slackened right off
There is not much heat @1000 rpm when just in gear - I happily motored round the harbour at this speed for 20+ minutes with no heat noticable
Heat appears at higher revs (2700/3000 rpm)
Now an admission (which might provide an easy answer)....In my naivity I thought 'grease is good' so when everything was in place I gave the stern tube / stuffing box a right good greasing via the lubricator. I now realise that this is not the smartest thing I might have done so.....
Do you think this is the reason for the heat or is something more sinister going on?
Will it damage the shaft/box if I run like this?
How can I solve the problem if it is the grease?
Thanks in advance and all advice will be greatfully received
Cheers
AF
Cheers
AF
