overcharging battery
Johnboy2004
23 Feb 2004
cork
hello
i am buying a new yacht, it is coming with 5hp outboard. i requested that the engine be able to charge the battery, is it just a simple task of connecting a cable from the engine alternator output directly to the battery? or would this damage the electornics , radio, navtex, that are connected to the battery ,etc on the boat and over charge the battery?
the engine i am talking about is the honda bf5 with charging alternator..
andyball
1 Jun 2001
I suggest a search here, since the topic's been covered a few times before & in some detail.
Ask the dealer..." does the honda bf5 have a rectifier fitted for battery charging ?"
If the answer's no, you'll need to buy/fit one & unless it's a regulating type keep an eye on battery voltage during extended high-speed engine use to make sure you don't exceed 16V.
jerryat
20 Mar 2004
Nr Plymouth
Hi Johnbuoy!
I'd be very surprised if output from such a small engine got anywhere near overcharging a reasonably sized 12v battery. Many moons ago I used to use a 9.9 Honda with charging facilites and never got anywhere near even fully charging the battery let alone over-charging it! This was even where several hours (X channel trips) of motoring was involved. I used to take the battery home periodically through the season and give it a boost from a 240v charger to avoid unduly shortening its life. As you are clearly going to use the power supplied by your motor to run instruments etc, you'll be quite safe in my view using it connected directly to the battery and unregulated.
Good sailing!
andyball
1 Jun 2001
an 80W alternator on a yam 8hp was more than able to exceed 16V into 150AH ( when the bank was well charged of course). I used to switch lights on to reduce the voltage if motoring at speed for any length of time.
Johnboy2004
23 Feb 2004
cork
attached the spec of the engine honda 5hp that i intend to use,.
would it take long to charge the battery from it.......or could it over charge the battery?
Type of 4-Stroke
OHV-1 Cylinder
Displacement (cm³)
127
Bore x Stroke (mm)
60 X 45
Full Throttle rpm Range
4000 - 5000
Rated Power hp (kW)
5 (3.7)
Cooling System
Water cooled
Carburation
1 Carburettor
Ignition System
Transistorized pointless
Exhaust
Underwater
Gear Ratio
2,1
Gear Shift
Forward-Neutral-Reverse
Alternator (W/Voltage Regulator)
3 amp
Propeller 4 Blades (inch)
7.88 X 7.50 inches
Dimensions (l,w - mm)
525, 340
Transom Height (mm)
445
Dry Weight (kg)
27
Oil Pressure Alert
Indicator lamp
Emergency Stop Switch
Revolution Limiter
Controls
Tiller Handle
Starting System
Recoil
Shaft
Short
Counter Rotation (for twin rig)
Engine Tilt
Manual
Engine Trim
Manual 5 stages
Power Thrust
