Tranona
For the first it may well be that the rail they are using is then connected electrically to the prop shaft either through the gearbox or using the Duff fitting that has brushes running on the propeller shaft. I have seen similar arrangements on boats with saildrives that live part of the time in fresh water and need to use a magnesium anode. I wire goes to the pushpit mounting stud inside and on the outside is a stud to which the hanging anode cable is clipped when needed.I have seen people hanging anodes over the side and clamping them to the guard rails. It was regularly done on a big 80 foot sailing yacht moored near me. So I guess that boats rails were bonded or he was wasting his time.
I think this is what reinforced my belief that all boat rails were bonded to the anode and/or the keel. I used to have an old Princess 37 that had steel radar arch and steel rails and I think they were bonded. Having read the ABYC recommendations on boat wiring I then assumed all boats were the same. Every days a school day.
On a similar vein, why do we bond fuel fillers and fuel tanks? I always assumed to it was to ground any possible sparks, but a spark will only happen if there is a circuit to complete. Not bonding them would surely be safer, as the fuel filler is connected to the tank via a non conducting rubber pipe and the tanks are usually connected via again non conducting rubber pipes either all the way or part way. Or is there another reason?
You are right - Princess and Moody (same factory) used to festoon their boats with unnecessary wires and anodes because they did not understand what they were doing. There is no need to bond tanks, fillers, through hulls to anodes in a grp hull. Post#13 covers most of the situations where anodes are needed in a GRP boat.
I can see the point of giving guard rails a path to earth for lightning protection. Equally anodes are often used now to earth the 240v shorepower system as required by the latest standards. Indeed I did this when installing shorepower on my boat because it was easy and also the method used by Bavaria on my previous boat. However, nothing to do with the anodes for the propeller.
