Nick_H
Fuel price for commercial craft is about half that, as no duty.
But they will use less so save .i guess those Thames Police boats - its taxpayers £ they are burning up !Fuel price for commercial craft is about half that, as no duty.
Yup-agree, but chance/ accidents happen -this may have been one .No dought the decision maker back then now has a gong ,but he would have had a trip to Buck Palice and mention in the new years honours list - anyhow irrespective of his performance in his " public funded body "Yep, if you're looking for examples of effective cost driven decision making, I wouldn't start with any publicly funded body!
My feeling is there are only two choices: shaft drives or outboards, everything else has major reliability problems.
Shaft drive has a simple gearbox/cutlass rubber bearing...can't get simpler than that.
Outboard has also got a simple 90 deg bottom leg gearbox; and the latest lean-burn outboards exactly match diesel fuel burn.
Outdrives, Ips, sail drive, .....etc etc is far to complicated and fragile and expensive to maintain.
Christ. Anyone would think that a outdrive was not an extremely uncomplicated bit of kit. 4 gears and 3 shafts. How easy do you want it?
I think there is a bit of thread drift here? The post was about whether or not outdrives are suited to commercial boats therefore cabin space, aft or otherwise, is not a concern.
Quote: "The Skipper is a mate of mine. They are D3 200's driving DPS."
http://www.bumblebee.gg/
Although, 'Bumblebee' looks great and 200Hp should be plenty, the D3 set up has not proven too well, I hear. It appears to be too weak in some experts' opinions, it was really designed for use on light weight sub 30 footers for weekend use.
I would have thought that for commercial use a D4-260 or D6-350 would on DPH drives (even with the extra weight) would have been much more industrial and with the extra power and torque, comes the lower operating revs, fuel savings and greater duty cycle.
I hope this brings you back on thread.:encouragement:
RR
... In fact thats one of the major reasons why outdrives have been so successful; it has allowed boat builders to offer far more accommodation in smaller boats than they could have dreamt of with a shaftdrive installation. The other reasons of course are ease of installation and superior performance/efficiency.
Can someone explain to me in simple terms why an outdrive is supposedly more efficient than a shaft?
Remember simple terms!
Shaftdrives have a rotating propshaft, P bracket and rudder causing drag. Sterndrives only have a smooth housing causing dragCan someone explain to me in simple terms why an outdrive is supposedly more efficient than a shaft?
Rudder=drag along with shaft+ P bktCan someone explain to me in simple terms why an outdrive is supposedly more efficient than a shaft?
Actually, they have a few "raisons d'être", but efficiency is not one of them.Sterndrives generally have 2 counter rotating props for additional efficiency
Well, comparing surface sterndrives with traditional shafts is a bit unfair, TBH.Given the added efficiency/lower drag of surface drives, I'd guess that the prop profile, being half, is also a factor?
At VP they can say what they wish, but whenever top efficiency is critical, you will never see a duoprop sterndrive.
Short answer, yes. On speed/fuel burn at WOT, at least.Are you saying that Volvo are lying?
