skyflyer
2-stroke, running fine at home in dustbin of water after winter service and spruce up. It started first or second pull every time. Only think I changed after that was fitting a new plug. It was stored inside since then until yesterday
Today I tried to start it on the dinghy having filled from - wait for it - half empty plastic tank of premix that had been on my boat all winter and was probably made up 9 to 12 months ago.
The outboard wouldn't start. I checked spark at plug, and noticed plug was damp but oddly it didn't smell much like petrol. The stuff in the tank does have a much stronger petrol smell
It occurred to me there might be water in the fuel so I drained the carb bowl by undoing drain plug and allowed the liquid to run free for a bit.. I noticed when some drips went into the water, accidentally, that rather than spread out over the surface in a rainbow, there were cloudy white billows dispersing beneath the surface.
I then tried starting it again and it sprang to life immediately for about ten seconds then died
So the obvious thing is now to try fresh fuel. But out of curiosity I have previously heard of old fuel going off, (which I had trouble believing) not least because the stuff I tested it with at home is probably almost as old! Does two stroke 50-1 mix spread out in the water like raw petrol or does the oil mixed into it make it emulsify and disperse?
Anyone like to make a best guess? Water in fuel or some sort of degradation? Similar experiences anyone?
I have undone air vent and fuel tap is on, by the way!
