kieronriley
what is the difference between semi synthetic two stroke outboard oil and the normal outboard oil ,and can I use it in an Johnson vro 70,thanks .Kieron
Hi Vic thanks very much for the answer it is all that I thought I needed. I've had the engine for two years but it hasn't had a lot of use, the vro has been ok so far so I will have to watch out for failure, are there any signs of failure that I should look out for, once again thank you for your help. Kieron
