davidpbo
The cable from the battery to the outboard has to pass through 2 bulkheads, one between the cabin and a reasonable well sealed external storge locker and then again from the locker into the engin well.
The cable is fairly substantial I would guess maybe 6mm CSA or more (Can't see the ends because they are crimped). Is there a small neet connector that could accommdate this size cable, one of which needs to be panel mounted?
I am fairly well up on that sort of thing but nothing is springing to mind. I did consider Speakon but I think 4mm is the biggest cable they can take.
It did occur to me I could use copper threaded stud through the fibreglass bulhead, with crimped eyelet connectors on the cable. The outboard coming out is likely to be an annual service event (I now use a hoist or gantry) rather than regular so removing a couple of nuts is not unduly onerous. Is there anything readily available? of concern to me is insulation and mechanical protection.
