wombat88
Do you let your 4 stroke outboard run until the carb empties after use? Or do you leave it only doing this if you are going to leave it for months at a time?
I do it every time, as I'm never really sure when I'm going to be using it again. If I know it will be for a long period, I drain the bowl too.
Yes.Do you let your 4 stroke outboard run until the carb empties after use?
Exactly, if peeps are going to run till it stops they need to realise the main jet is above the bottom of the bowl so some fuel is still left in the bowl. It can be counter productive in that there is less to evaporate so the remnants happen quicker!I don't do anything until I'm packing up to leave to boat when I always drain the carb fully using the drain screw. I know that I will not be returning for at least a month.
Richard
I don't run it dry except for the winter, but I'm usually back within 2 weeks, also I use premium ethanol free fuel to avoid the varnish.
Honda 2.3 4 stroke.
I've stripped down plenty of two-strokes after running the carbs 'dry', I've never found the innards anything but oily.
