JohnK
At the risk of being accused of being a "taker" and not a "giver" on this forum, here's my second question:
I have an old Suzuki DT50 outboard, since it has been serviced it revs uncontrollably. If you gently increase the revs up to about 1500 RPM all is well, but, if you take the revs higher (either with the idle throttle or main control) the revs won't drop until you stop the engine. When the engine is restarted all is well again until you rev it.
As far as I can see all levers and linkages are returning when you move the levers back (including the ignition advance) when the engine is running.
Any ideas?
TIA,
John
Any ideas?
TIA,
John
