Outboard or inboard
I know these diesel outboards aren't gaining much traction in the leisure market yet - but I wonder why.
OXE Diesel - Worlds leading outboard diesel engines
The World's Most Powerful Diesel Outboard Motor - Cox Marine
I think cost is the issue (What does a 300HP petrol outboard cost for example?) - However I am surprised that those boats that would have had a Diesel sterndrive in the "old days" haven't bought into them.
I know £40,000 is a lot for 300 hp - but compared to a D4-320 inboard + DP Sterndrive for example, is the cost that much more?
The makers claim (well they would wouldn't they) that as commercially rated motors they have a much longer service life - and fuel consumption around 50% (one review I saw was that at 3950 rpm and 25knts it was burning 5.9lph
Really surprised these aren't getting popular - the OXE especially as they have a range from 125-300hp whereas the COX is only a 300HP motor.
When I see the cost of a typical 40' boat now with twin 300 outboards it makes my eyes water - an extra £20k would barely be noticed, especially as I would suspect that the resale would be much higher given it is a "best of both worlds" solution. Weight isn't too bad - 350KG for the OXE which isn't THAT much more than a 300HP Petrol engine - and actually the torque being SO much higher, I suspect you'd get similar performance to a 350 or even 400HP petrol outboard in terms of cruising even if not pure top-end.
So why aren't we seeing these engines entering the leisure market.
If (and it's a huge if to be fair) I could afford a bit 30-40' boat, new with outboards, I'd want these not petrol on the back for all the range and other issues not just the massive fuel saving.
So to compare a OXE 300 HP to the Yamaha 350 hp
Note, I've had to guess the Yam torque as the website doesn't quote it - so I've just worked on the peak power and divided by the speed - the reality is the torque peak may well be higher at a lower speed.....
Yamaha 350OXE 300
Power350300
Torque334 Lb/ft @ 5500 rpm
452 NM
680NM @ 1750 rpm
Weight346kg395kg
Alternator output50A180A
Service Interval? not sure200hrs minor
800hrs major
Fuel Burn WOT129lph70?
To me that OXE is a winning engine - especially with that torque and fuel burn if you have a heavy boat and top speed isn't the be all and end all.
At cruise I expect the Yam would burn 60 ish lph and if you look in their "brochure" - at 2500 rpm it looks to be well under 30 on the OXE - so that gives double the cruise range from a tank, plus cheaper fuel plus (perhaps) increased resale?
Yamaha 350OXE 300
Power350300
452 NM
680NM @ 1750 rpm
Weight346kg395kg
800hrs major
It could all be timing. I know there have been diesel outboards forever, but these new ones are coming on stream just at the time in history when an adventurous outboarder might think electric, if he wanted to be radical
As discussed elsewhere tho Electric isn't now and possibly never will be viable for boats. Cars yes, but the massive battery capacity for a boat (perhaps 1500KWh for a 30 foot boat) - carrying the batteries a problem, cost outrageous but recharging them, completely impractical.
A 70% reduction is huge - what the car industry faced 20 years ago basically.
They will do it, they have to - but the cost will go up on the outboards a lot. going back to that OXE outboard - it claims to have much lower CO2 and 70% less HC+NOx so again a move might make sense.....
Does anyone know how much the OXE 200 & 300 HP are and the COX 300 and how that compares to a 200 / 300 outboard (although for heavier boats - perhaps its more akin to a 250 or 350 outboard because of the Torque?
I believe that the main reason that Boat Manufacturers have moved from Inboard Diesels to Outboards is Cash Flow.
Consider this, a manufacturer which was fitting Inboard Diesels had to buy them in and fit them as part of the construction and they were only paid for when the dealer bought the, so it could be a year between manufacture and receiving payment.
But the Boat Manufacturer who moved to Outboard Power boats did not have to fund the outboard, they could just get on with making the boat although they would have to install controls etc. Then the boat goes out to the dealer and its only when sold that the dealer has to buy the Outboard.
Diesel is still cheap and engines today have a lot more power. I would not buy an outboard boat.
I think volvo has some kind of credit arrangement with boat builders which is why every boat has volvos
I see the cost thing, but the weight seems about the same - perhaps 40kg in it.
Do we know what the COX and OXE cost over here, vs a petrol? I know the o/b in the US are chump change - when I imported boats from the US at the start of 2020 I could get a Yamaha for a good 35-40% less pre-installed over there than over here.
Yamaha 350OXE 300
Power350300
452 NM
680NM @ 1750 rpm
Weight346kg395kg
800hrs major
I would only want a boat designed for the Oxe. I wouldn’t want to be the first to expriment with that much torque on the transom. Also I’d like to hear how much noise it makes
Just watched the x shore video on YouTube looks like a pretty impressive electric boat 0-20 in 4.5 seconds too
