longjohnsilver
I’ve got a Yamaha f60, about 3 yrs old. Do I need oil specified for outboards, or can I use 10W 40 from my local engine oil supplier? Is there anything special about Yamalube oil?
Afaik yamalube is synthetic. I have seen it positively recommended by us mechanics online for the f70 which is your engine but 4valves and 6400 rpm ish, but decent 10-40 should be fine in f60 and most other models esp as it probably gets changed at <100 hrs. (My 6 yr old f70 has 103 hours and 3 oil changes at least)
Check the specifications and you can often find similar specs for much less money.
