tyce
i have been removing the paint ready to epoxy it on my hunter horizon 272 (1989), and unfortunately i have found a lot of blisters.
the blisters are no more than 6-7mm diameter i could not see them until all paint was removed and i was sanding even then i could only see the outline,so they arent raised and are flush with the gel coat, just the outline is visible after sanding, when you press against them i can hear a cracking noise and some let out a bit of water.
i assume this is the dreaded osmosis,and having never seen it, i was hoping you could give me some advice, is it osmosis or wicking, is it wise to epoxy coat it now, or am i better of monitoring it, and eventually having it repaired, and at what state is it deemed vital i repair it, would you class this as very mild osmosis and could i get away with epoxying it
