CalicoJack
How long shouldd a full osmosis treatment last, ie gel coat peeled, hull filled and faired, treated with Intershield and the cooper coated?
I have seen osmosis return within 5 years, but it's usually just outside of the guarantee period.Sorry, I wasn’t very clear how long will it last once completed before you might expect osmosis to return?
I agree. It's a waste of money.I would not waste the time on getting it sorted, enjoy the sunshine and go sailing. There is no record of any boat dissolving in water due to osmosis and life is short.
All depends on the condition of the gelcoat and the laminate under the gelcoat: you might have greatly reduced the chance of blisters developing, or you might have accelerated the development of incipient blisters by sealing in moisture. Did you get a moisture check on the hull befoire epoxying?i got my entire hull down to gelcoat during lockdown as naf all else to do , ive put 3 layers of epoxy paint and 2 layers of vinyguard and 2 layers of antifoul would that be enough to guard against osmosis, luckily there was no signs of osmosis.
I never got a moisture check but the boat has been out of the water since October so i am crossing my fingers and hoping for the best.All depends on the condition of the gelcoat and the laminate under the gelcoat: you might have greatly reduced the chance of blisters developing, or you might have accelerated the development of incipient blisters by sealing in moisture. Did you get a moisture check on the hull befoire epoxying?
I'm actually personally not too worried about "osmosis" in an old and heavily laid up hull. I bought a boat with maybe 200 very defnite blisters, quickly individually ground out and filled, without any prolonged drying. Something like 12 years later there were maybe 20 new blisters when I sold the boat.
Assuming that it is water getting into the hull that causes "osmosis" (opinions occasionally vary but it is definitely true that it never ever happens with GRP that doesn't get wet), then if water molecules take 20 to 30 years to get in they are not going to escape that much in 6 months. I tend to regard time ashore as time the water is under no pressure to get in, rather than much deep drying out happening.I never got a moisture check but the boat has been out of the water since October so i am crossing my fingers and hoping for the best.
The boat was out if the water for about 8 years and only been in for last 18 months and is on a drying mooring not sure if that would help.Assuming that it is water getting into the hull that causes "osmosis" (opinions occasionally vary but it is definitely true that it never ever happens with GRP that doesn't get wet), then if water molecules take 20 to 30 years to get in they are not going to escape that much in 6 months. I tend to regard time ashore as time the water is under no pressure to get in, rather than much deep drying out happening.
A boat that might get blisters in 15 years if always in the water might be fine for 30 years or more if out for six months year. The other big factors are water temperature and salinity. The warmer the water definitely the faster you get blisters, and freshwater seems worse than salt.
We had ours done about 7 years ago, and I’ve just found some nasty smelly blisters. Damn! normal or just unlucky?
